mako74 avatar image
mako74 asked
Multiplus 12V-3000VA vs 12V-2000VA differences (except the output power)
Hi all. Happy to find this forum as I begin my van conversion.
I've been peeping over this layout from exlorist.life. I'm planning on doing a similar set up, but a bit smaller:
Victron MultiPlus C 12/2000 / 80-30
Victron SmartSolar MPPT 100/50
2 x 150Ah LiFePO4 batteries (max input 100A, max. output 150A) in
2 x 180W Solar in series (total ~44A VoC)
Now, I've been trying to get my head around the differences between these two Multiplus', but I'm still a bit unsure. So, could someone tell me does the 12V-3000VA have some other advantages over the 12V-2000VA than power output? Also, can I set up maximum charging current in the Multiplus 12V-3000VA so not to over charge my 100Ah capable batteries?
I'm happy to go with the 12V-2000, but my dealer has a good price on the 12V-3000 so I'm tempted.
Thanks in advance!
jwfrary avatar image
jwfrary answered ·
Well physical size!!
slightly more power consumption at idle
If it’s the 50amp transfer switch version you get more aux inputs and programmable relays.
Otherwise they are broadly the same.
