tkmbe avatar image
tkmbe asked
Cannot connect anymore to smart solar mppt 100/15 firmware 1.54
Hello
I connected with my cel phone to myto smart solar mppt 100/15 with fw 1.54.
After freezing connection I tried to connect with other one. Nor new one nor old one can connect again.
The charger shows the device greyed out. I have diasabled bluetooth etc rebooted cell phones.
No chance. This happens since about 2 week.
Impossible to connect.
What is the right way do solve the problem?
Do I have to disconect all power so device shuts off?
Is there no other solution?
This never happened with older fw...
MPPT Controllers
Paul B avatar image
Paul B answered ·
Yes try disconnecting all power to the Smartsolar reg inc the solar connections wait 5 min , then reconnect the power, battery first then solar
then see if the bluetooth will connect again.
NOTE you can ONLY connect one phone device at a time , so if another device is connected then you will not be able to connect untill that other device has disconnected
