Hi. What needs to be done to get the battery status to show correct? CCGX show full batt even when the voltage is low. 24 V is taken directly pass the CCGX so is a BMV needed?
Hi, Here is some info that might help:
https://www.victronenergy.com/live/ccgx:start#battery_state_of_charge_soc
See section - 2.2
In my experience, if you require accurate SOC then it is best to have a shunt - bmv or smartshunt
*Edited*
23 People are following this question.
