For example can a Buck Boost and Orion-Tr isolated version work together in parallel? I assume so if both are isolated; is anyone sure?
While each has it’s own isolation circuitry to protect it from damaging the ‘main’ battery they will likely have problems being in the same charge mode as they don‘t talk to each other.
21 People are following this question.
