There is usually more concern over minimum requirements of the bank not being met. Such as the c rating of the bank meeting the full load and possibly short term overload needs.
Maximum is usually determined by budget and charging ability, as well as the number of days of autonomous running required.
Hi @Jesse
As @Alexandra mentioned already your questions seems really weird, but I will answer anyhow:
65000Ah
If you walk about a big battery Bank (Lead Acid) why not use am BMV, doesnt add much to the costs compared to THIS Battery.
If you talk about a Lithium system with external BMS the Capacity you can connect is unlimited.
Please make sure that you respect leadacid MINIMUM Charging Currents of the battery supplier!!!
BR
23 People are following this question.
