carlbrinkmann avatar image
carlbrinkmann asked
PMP482305010 hw rev 14 changes
Our manufacturer received PMP482305010 with hardware revision 14.
Do you know if we can still use 2629470.vff to update the firmware on inverters with hardware revisions 14?
Are there any wiring requirement changes we should be aware of?
Where could I find more information on hardware revision changes?
Multiplus-II
Warwick Bruce Chapman avatar image
Warwick Bruce Chapman answered ·
Per https://www.victronenergy.com/upload/documents/MultiPlus-II-to-MultiGrid-and-MultiPlus-comparison-EN.pdf, the PMP482305010 is the current version (ie. 2629) and the firmware file 26294xx.vff will work.
carlbrinkmann answered ·
Thanks warwick,
Do you know where I can find more information on hardware revision changes?
4 comments
Warwick Bruce Chapman avatar image Warwick Bruce Chapman commented ·
Google "VEBus firmware numbers.txt" and find every unique hardware model listed.
Current version is pasted below but I snipped out the old microprocessor versions because the document was too long to post:
For an explanation of firmware numbers, see this document:
http://www.victronenergy.com/upload/documents/manual-VE.Bus-firmware-versions-explained-EN.pdf
List of models:
Old microprocessor 230VAC
<snip>
Old microprocessor 120VAC
<snip>
2060 Phoenix 12/3000/120-50-120/240V
2062 MultiPlus Compact 12/2000/80-50(30)-120/240V
2071 Quattro 24/5000/120-2x60-120/240V
2072 MultiPlus Compact 24/2000/50-50(30)-120/240V
New microprocessor 230VAC
2600 MultiPlus 12/3000/120-50
2603 Phoenix Multi Compact 12/800/35-16
2605 MultiPlus-II 12/3000/120-32
2606 MultiPlus Compact 12/1600/70-16
2607 MultiPlus Compact 12/1200/50-16
2608 MultiPlus Compact 12/2000/80-30
2609 MultiPlus 12/3000/120-16
2610 MultiPlus 24/3000/70-50 (+EasySolar)
2611 MultiPlus-II 24/3000/70-32
2612 MultiPlus 24/3000/70-16
2613 Phoenix Multi Compact 24/800/16-16
2614 MultiPlus 24/5000/120-100
2616 MultiPlus Compact 24/1600/40-16
2617 MultiPlus Compact 24/1200/25-16
2618 MultiPlus Compact 24/2000/50-30
2620 MultiPlus 48/3000/35-50 (+EasySolar)
2622 MultiPlus 48/3000/35-16
2623 MultiPlus-II 48/5000/70-50 (ACOut2 switchable etc)
2624 MultiPlus 48/5000/70-100 (+EasySolar)
2625 MultiPlus-II 48/3000/35-32 (externe sensor max 32A)
2628 MultiPlus-II 48/3000/35-32 (externe sensor max 50A)
2629 MultiPlus-II 48/3000/35-32 (ACOut2 switchable etc) (+EasySolar)
2631 Quattro 12/3000/120-50/30
2633 Quattro 12/5000/220-2x75
2634 Quattro 12/3000/120-2x50
2641 Quattro 24/3000/70-50/30
2642 Quattro 24/5000/120-50/30
2643 Quattro 24/8000/200-2x100
2644 Quattro 24/3000/70-2x50
2648 Quattro 24/5000/120-2x100
2649 MultiPlus 24/5000/120-50
2652 Quattro 48/5000/70-50/30
2653 Quattro 48/10000/140-2x100
2654 Quattro 48/8000/110-2x100
2655 Quattro 48/8000/110-2x100
2656 Quattro 48/15000/200-2x100
2657 Quattro 48/5000/70-2x100-S
2658 Quattro 48/5000/70-2x100
2659 MultiPlus 48/5000/70-50
2660 Multi 12/500/20-16
2661 MultiPlus 12/800/35-16
2662 MultiPlus 12/1200/50-16
2663 MultiPlus 12/1600/70-16
2665 Multi 24/500/10-16
2666 MultiPlus 24/800/16-16
2667 MultiPlus 24/1200/25-16
2668 MultiPlus 24/1600/40-16
2670 Multi 48/500/6-16
2671 MultiPlus 48/800/8-16
2672 MultiPlus 48/1200/13-16
2673 MultiPlus 48/1600/20-16
2680 MultiGrid 12/3000/120-50
2685 MultiGrid 24/3000/70-50
2690 MultiGrid 48/3000/35-50
New microprocessor 120VAC
2702 MultiPlus 12/3000/120-50 120V
2708 MultiPlus Compact 12/2000/80-50 120V
2712 MultiPlus 24/3000/70-50 120V
2718 MultiPlus Compact 24/2000/50-50 120V
2733 Quattro 12/5000/120-2x100 120V
2748 Quattro 24/5000/120-2x100 120V
2751 Quattro 48/3000/35-2x50 120V
2753 Quattro 48/5000/70-2x100 120V
2754 Quattro 48/10000/140-2x100 120V
seb71 avatar image seb71 Warwick Bruce Chapman commented ·
He was asking about hardware revisions. Those you listed are (major) model numbers. A certain model number might come in different hardware revisions.
carlbrinkmann avatar image carlbrinkmann seb71 commented ·
Hi @Seb71,
I'm still not able to find more information on hardware revisions.
Do you know where to find more information?
Thanks,
Carl
seb71 avatar image seb71 carlbrinkmann commented ·
If you currently have a 2629xxx firmware, as long as you update to another 2629 firmware, I think that you should be safe for all hardware revisions of 2629 released so far.
For extra safety you can update the firmware using Victron Connect (update to the firmware version that Victron Connect autodetects and says it is the last one for your inverter).
I have the same Multiplus II 3000/48 PMP482305010 (2629), but mine is Hardware Revision 12C and it came from the factory with 2629459 firmware.
I updated the firmware on it a few times.
I currently have 481 firmware (2629481).
Latest version for it right now is 482.
