karam-el-bayed avatar image
karam-el-bayed asked
Heat Dissipation from the SmartSolar-MPPT-250/100
Dear All,
I am designing an Off-Grid Solar Power System to be installed in an ATEX Certified Boxes (SS 316, 25mm thickness, IP 65). The system will require 2 x MMPT 250/100 charge controllers installed inside one box (approx. 1200 x 800 x 300 mm) and running at an ambient temperature of 50 Deg. C.
I know that the charge controller will de-rate as the temperature goes up. what I don't know is what are the heat dissipation figures for these controllers and couldn't find it anywhere in the Victron literature.
Helpsolar sizing
