Can I use victron (1)Multi plus 2000/80 and a (1) Multi plus 3000/120 in parallel on a 230/110 distribution panel
Sorry to say but as far as I know this is not possible. only the same size and model units can be connected in parallel ie multiplus 12 volt 3000/120/16 with a multiplus 12 volt 3000/120/16 and the firmware must also be the same version as well, but you can download and update these
4 People are following this question.
