jefndeb avatar image
jefndeb asked
Multiplus Charger jumps to 15 volts randomly?
Hello from Savanah Ga.....
I have randomly seen this charger go up to 15 Volts and slowly drop back down ....not sure why...and I of course receive "High Voltage Alarms" (set at 14.6)
I understand that AGM batteries are sensitive to being over charged so I was reading up on this...and the 15 volts was concerning....
Thanks for any suggestions....I installed this 2 weeks ago and am still learning..
I attached schematics for refence.
charger
Paul B avatar image
Paul B answered ·
I would check the settings for the MPPT and the multiplus and make sure they are set correctly. and also check any other charging source ie engine alternator etc etc
jefndeb answered ·
Sorry, I should have mentioned the MPPT was only installed for future solar install. its not currently connected...
klim8skeptic avatar image
klim8skeptic answered ·
Has voltage compensation for the multi been set up correctly at the battery posts?
