tomzinn avatar image
tomzinn asked
MPPT 75|15 and BMV 712 issues
I have an existing system that was working find for the last couple years.
One solar panel on my truck connected into an MPPT 75|15 and a BMV 172 meter.
Both were able to connect via bluetooth to an iphone and everything worked great.
I had the solar panel off for the last few months while installing a new canopy and roof top tent with a new solar panel. Everything in on and connected.
When I plug in the solar panel, I get a 9A draw visible in the BMV712 that slowly dials down to 2.5A and stays there. Battery voltage has been up to 14V according to the BMV.
The 75|15 will no longer connect via bluetooth and I have no idea if this is even working any more.
Today I installed a new 75|15 thinking it may have gone bad but it behaves the same way. I reconnected the old one and it's the same.,
Anyone have any ideas what might be going on here?
MPPT Controllers
Justin Cook avatar image
Justin Cook answered ·
@tomzinn, is it possible you connected the controller to the wrong side of the BMV shunt when you reconnected it?
If a charge source is connected to the wrong side of the shunt, a charge will show as a load...
tomzinn answered ·
Aha, that certainly could be it as I moved that part of the wiring.
I'll move the shunt and see what happens.
Any thoughts on the lack of bluetooth connectivity to the smartsolar mppt? That stopped working before I changed anything.
Thanks for the response! Much appreciated.
rodneyab avatar image rodneyab commented ·
I have found that powering down the iPhone, waiting a few minutes then repowering it, will permit good bluetooth connectivity between all VE devices on my list for several minutes. If my attention lapses and/or I do some other task, the bluetooth will be down, and I'll have to power down and repower the iPhone.
