abefroman avatar image
abefroman asked
Max output current limited by MPPT Calculator Recommendation
When using the online MPPT calculator the recommended charge controller is the 100/20. It indicates the Max output current will be limited at low temps. I ran the same setup in the Excel calculator, and see that the potential Max current is 27.6A with a 100/30 MPPT. Is there a reason why the online calculator is recommending a 100/20? Should I go with that over the 100/30? It's shown below, but for reference I'm using 2 Newpowa 150W panels in series.
Thanks!
MPPT Controllers
To get the maximum out of the panels you should use the 100/30. I don't know why the online calculator always recommend a to small MPPT but I already forwarded it to the devs.
