Does the above inverter/charger have a bonded neutral / ground ? I'm using a EMS that needs a bonded neutral
Hi @ragscar, welcome to the Community!
Neutral/Ground may only ever be bonded in one place, so while the unit is plugged in to "shore power", the neutral/ground bond is provided from shore.
While inverting, the N/G bond is provided by the unit itself, so long as the ground relay is not disabled (see Section 10.3.2 of the VictronConnect VE.Bus Configuration Guide).
23 People are following this question.
