Hi all
Can OR should I conect a ve direct cable from my pheonix 800 inverter to the ve direct port on a BMV-712 ?
Chrisb
Hi all
Chrisb
Hi @Chrisb077,
no. There is no data communication between the Phoenix Inverter and the BMV.
So It won't use the BMVs blue tooth to be able to view/change inverter settings via the VE-direct cable ? I will still have to get a VE to Bluetooth dongle for the inverter ?
@Chrisb077,
yes exactly. Using a VE.Direct Bluetooth Smart Dongle, you can view and change settings on the Phoenix Inverter.
23 People are following this question.
