I have a Quattro 10kva 240v. If I connect a generator with 37amp at 240v what will be my charge current to my 48v Lithium Battery?
Thanks exactly what I thought. Not sure what is the Quattro's max charge current.
The max charge current of the 10kVA Quattro is 140A. By default the current is set to 2/3 of the max, so about 93A in that case. To charge the settings you will need a MK3 Interface and VE.config or VictronConnect.
24 People are following this question.
