anadal avatar image
anadal asked
Inverter/charger 12/2000/80 not charging
  1. I have a Multiplus 12-2000-80 inverter charger.
    When generator is on, i can use the inverter but can’t turn on the charger.
    - i used to turn on Generator , Turn on inverter to help start AC , then switch back to “charger only”. Now as soon as i switch to charger only, power does not come in anymore from generator. , if i go back to switching to inverter , power comes back on from Generator.
    It worked for about 6 months .
charger
Check the fuses between the Multi and the battery. The 2000VA Multi also has a internal fuse.
mbohrson avatar image mbohrson commented ·
I am having this same issue, fuses are okay, where is the internal fuse located?
Chargers.
