jon-lowbank avatar image
jon-lowbank asked
Stop MPPT Charging via relay when connect to GX device.
I have a Cerbo GX a MultiPlus and a SmartSolar MPPT 250/100.
I have a custom Lithium Battery with allow to Charger and Allow to Discharge Dry contracts.
If I have the MTTP connected to the GX device Via a VE.Direct cable I can not use the VE.Direct non-inverting remote on-off cable.
How can I stop the MTTP Changing by a relay and also have the MPPT connected to a Cerbo GX ?
MPPT Controllers
klim8skeptic avatar image
klim8skeptic answered ·
A brief glance at the Installation Manual shows you can use the remote port to enable/disable charge. Page 7..
jon-lowbank avatar image jon-lowbank commented ·
My bad haven't had this terminal on other models I've used I assume it on the VE.can model as well.
