Hi. I have been unable to connect to my controller via the app today using both my iPhone and iPad. The screen gets stuck at 20%. Worked flawlessly until now. Have tried resetting pin on dongle but after 5 seconds the red error light flashes.
Hi @mike_h
Pressing the reset button caused to dongle to only reset the pin code. So before you can connect with the iPhone or iPad, you need to "forget this device" in the bluetooth settings menu. The procedure is shown here in a short video: https://www.victronenergy.com/live/victronconnect:start#bluetooth_smart_-_removing_from_the_list_of_paired_devices
After this, the iPhone and iPad should be able to connect again, although you need to fill in the pincode again.
If you are still unable to connect, you can try to disconnect the dongle for 10 seconds and then reconnect.
Kind regards,
Thiemo van Engelen
Thanks Thiemo. This has worked!
Hi @mike_h
Just so we and the community knows, what has worked? Did you only do the "forget the device" or did you also have to disconnect and reconnect the dongle?
And can you please mark my answer as Accepted answer so it is also clear for others that this was a solution?
Kind regards,
Thiemo van Engelen
25 People are following this question.
