Michael Schmidt avatar image
Michael Schmidt asked
Wrong calculation of battery usage in vrm history
The battery usage in vrm seems to be not correct in some ess builds.
i have 2 builds that have totally wrong data.
i checked:
the correct phase (L1)
the battery monitor
the system setup
but still the history says 1.kwh was used from solar and 1kwh from battery
but this is wrong as i can see in enhanced graphics with grid
system is multiplus II 48/5000
and also multiplus 12/3000
Multiplus-II
@Michael Schmidt
If you used 1kwh from the battery then surely it would use 1kwh to charge the battery again in an ess system? Maybe I am misunderstanding and more information is needed.
What is the consumption saying verses the grid useage?
What other components do you have in the system? Energy meters?
