sydney6 avatar image
sydney6 asked
Victron Battery Monitor at 100%
Hey I’m looking for some help. So I have gone through all the answers and I still can’t figure this out. The SOC stays at 100%. I have changed all the settings reset it. I made sure everything was plugged in properly. Right now I have the charged voltage at 12.8 and all the other settings are right. The voyage being read currently is 12.5 but it is still hovering me a SOC at 100% I have 2 AGM batteries wired in parallel. The battery side of the shunt is to the negative and the load side is to my negative bus bar with all the loads and the ground. The red monitor cable is connected to my possibile bus bar with all the loads. I have no idea how to fix this!
BMV Battery Monitor
Murray van Graan avatar image Murray van Graan commented ·
Have you “zero calibrated” your BMV?
