innovativeecohomes avatar image
innovativeecohomes asked
Positive x Earth voltage low on test
Victron phoenix 12/800 inverter installed on a steel Hull boat
When I test across live and negative I get 220v. When I test live to earth I'm getting 140v and when a load is applied I'm getting 80v.
I have replace the inverter and get the same issue. I have run a negative cable to the Hull and the problem persists. The appliance I want to run requires a good earth to run properly.
Any ideas. Help much appreciated.
voltage
wkirby avatar image
wkirby answered ·
These models are shipped with the AC output isolated from the chassis.
You need to follow the instructions in the manual, see Appendix A on page 12 of the manual linked below:
https://www.victronenergy.com/upload/documents/Manual-Phoenix-Inverter-VE.Direct-250VA-1200VA-EN-NL-FR-DE-ES-IT.pdf
