nickdb avatar image
nickdb asked
Optimise BMV SOC detection with ESS
I have a BMV712 connected to 4 x 220AH Victron Gel batteries in series, an MP2 3kVA and a 150/45 MPPT using ESS.
I put the bmv in when it became obvious that the MP2 was useless at accurately reporting SOC.
I have tuned the BMV as per docs and some guidance from victron (charge voltage midway between float and absorption, extended the time needed to sync to 8 minutes and reduced the tail current to 1.9%).
This works most of the time, the SOC gets to around 98% and then syncs.
Where it falls apart is if when there are bad PV days and the charge voltage is closer to float, the batteries don't sync. after a couple of days you end up with charged batteries but with a decreasing SOC reported.
When batteries discharge you now hit the ESS SOC limit too quickly (only use top 30%) which means the batteries never discharge far enough to hit bulk/absorption.
You're now get stuck in this float/discharge cycle, with battersafe increasing limits making it worse.
Being unable to force a remote sync means it is a real problem to break this cycle without having to start changing the ESS schedules and limits.
Is there a better way to setup the BMV?
For those doing partial discharge of batteries it isn't difficult to end up in this loop.
ESSBMV Battery MonitorSOC
Remote sync via VRM, will help break this loop.
Still keen to know if there is a better way to tune the shunt, or if I have to live with it.
The hybrid (both solar and backup power) approach seems to have its challenges.
alan avatar image
alan answered ·
If the charge voltage hits closer to float, the batteries will be nowhere near charged as they haven't even gone through the absorption phase.
