seanmc1 avatar image
seanmc1 asked
Wiring for BMV 712.
Hi All just looking for confirmation of the correct connection for the shunt for my new BMV 712 battery management system.
Above is a photo of the main battery switches (back and front) with the negative in the middle. The connection on the right of the first photo as you look, is the cable from the batteries. Is this the cable that should be connected to the shunt? And an additional cable from the shunt to the switch?
BMV Battery Monitor
tony-c avatar image
tony-c answered ·
Hope helps the shunt is in the Negative
