Will MPPT 75/15 draw down battery in winter with no panels attached?
Getting ready to store the boat for the winter and I am taking the panels down. Do i need to disconnect the MPPT's from the house bank?
Thanks
Thanks
There is a minimal self consumption. Manual states 25mA however not sure if that is in operation or standby.
@nyodyssey410
Battery self discharge is also a factor to consider.
If you are disconnecting the panels, you might as well disconnect the battery as well. If left connected it will draw approximately 4 Ah per week.
On a 100Ah battery that is a considerable amount, on a 1000Ah not so much.
By the time you add all the parasite loads together, you are best to either leave your battery on a charger or disconnect the battery completely.
Even disconnected completely a lead acid battery will benefit from being changed at least once every month or two whilst in storage.
29 People are following this question.
