When we select the country Grid "France VDE 0126-1-1 VFR2019"
The over frequency seems not to be OK. Indicated value is 50,6 Hz but should be 51,5 Hz.
Please confirm the adjustments
Hi Avnor, we’ll double check and come back to you Thank you
Hi again, we checked and it the mistake is only there in the table shown in VEConfigure. The parameter used in the firmware of the product is OK.
The table in VEConfigure will be corrected on the next release - thank you for noticing!
28 People are following this question.
