Hi
I take it the solar charge controllers will be dc coupled as In connected straight to the battery’s ?
If this is the case it will have me bearing affective on the multiplus
The multi will just be the user of the energy the battery’s have available which have be charged by the pv and solar charge controllers.
if I google for 'BL-SML4860' I find a DC solar charge controller, that's good, nothing to do with the capability's of the MultiPlus. (if your batteries can handle it)
If it would be 2x AC solar inverters, two on the output is too much, but you could wire one to the input side of the MultiPlus and one on the output.
(these questions are hard to answer with this little information)
Yes, they are DC Controllers. Connected directly to a Topband Lithium battery (48V/300ah) trough the Multiplus.
I assume the Controllers are controlled by the BMS of this Topband batteries?
I do not think they comunicate very well if at all. The controllers and the battery are only connected at the Multiplus battery conjunctions. With full battery, sometimes the BMS shut down the battery due to high voltage (65,4 V) at daylight. Regardless if the system is of or on grid. Should it be another connection between battery and controllers?
3 People are following this question.
