Veso_58 avatar image
Veso_58 asked
Help need Quattro48v 5000
Dear Sirs, We own your Quattro 5000 inverter, with the goal of being independent of the Distribution Supplier with Solar Energy. It is connected with 12 x 330w panels connected in 4 rows of 3 in a row and 300Ah x4 / 48v batteries. The AC input is to AC IN1. In our case, should solar energy, when present, have priority in supplying consumers? What is the general concept of work, purpose and priority of consumer power supply? We have a constant power consumption of 2kW. Is the visual signaling in the attached picture normal when our batteries are 70% full and AC1 is on. It bothers us that this is why the energy obtained in the batteries from the sun is not consumed first. Please direct us to the proper operation of this configuration.
Thanks!
vax avatar image
vax answered ·
Hi did you get an answer for that? I have similar question about the difference between on position and inverter only.
Inverter only is zero grid supply but what exactly is "on" mode? Does the solar charge take priority then when no solar power it automatically switches to grid? confusing yes.
