magus avatar image
magus asked
Hardware Upgrade change from Raspberry Pi 2B to 3B
I need to upgrade the Hardware to a new Pi, does switching the SD Card to the new Pi fit the needs or do i have to perform additional tasks?
thanks in advance
m.
Venus OSRaspberry Pi
jeroen avatar image
jeroen answered ·
the raspberrypi2 & 3 use the same image. So unless you made custom modifications, you can simply place it in the rpi3 and it should boot.
(it will get a new VRM id btw)
