gmd avatar image
gmd asked
Multiplus Setting Max Charge Current Remotely
Hi everyone,
I am familiar with Modbus-TCP, have built my own interfaces to replace Multicontrol for example.
In the latest field list for device communication there is still no reference to reading or setting charge current limits. One can thing of workarounds using the AC limit, however this is glumpsy.
The limit can be set with Configure or also now with Connect (Section 10 of the manual).
Is there a documented API Connect is using, which I can use from my software to configure the charger dynamically ? MK3/USB, Lan or whatever does not matter as long as I can access the fields.
regards
Gmd
