jesseflorig avatar image
jesseflorig asked
Highest W 12V solar panel for MPPT 100/50
I've been having a hard time finding 300+W 12V panels to use with MPPT 100/50. The few 350/400+W panels all seem to be 24/48V. Has anyone had better luck locating such a panel or are there technical limits as to why this might not exist?
EDIT: For reference, I found this Renogy 200W 12V but the spec sheet shows the open circuit voltage as 24V, which I guess I'm not understanding how to look at the spec sheet to determine 12V compatability.
MPPT Controllers
Vance Mitchell avatar image
Vance Mitchell answered ·
An MPPT controller can accept a higher voltage and convert it into a lower voltage for battery charging.
In the case of a 100/50, it can accept up to 100v from the solar panels and convert it to your battery voltage.
I would leave a safety margin still and keep it below 90v Voc to allow for temperature variations.
You could happily connect 3 x Renogy RSP200D panels in series to that controller giving you a 72.3v Voc.
If you use the MPPT calculator and input the panel specifications and system voltage, it will let you know if the panels are acceptable.
Most of the 350-400w panels Will have a Voc around 35-50v, so will work fine with that controller and 2 of them could be connected in series or parallel depending on their specifications.
