kellymeer avatar image
No Watts No Amps
I built a solar suitcase with 2x100 Watt Renogy panels. I have double checked every thing, but never gets watts or amps. I am unplugged, and running the inverter, both TVs, all lights and exhaust hood. So there is load.
the voltage on the airstream monitor and with a meter is 12.5 volts. App says battery voltage at 14.6 volts and in absorption. It acts like an open circuit. No change when I plug and unplug.
2019 Airstream 27FB with 2 BattleBorn batteries in parallel.
I am confused. What am I missing?
not charging
Matthias, thanks. You are 100% correct. It was a blown fuse on the controller. I forgot about that one. I kept measuring the voltage on the controller terminals.
so, like always, check your fuses!
I guess there is a blown fuse/breaker or a open switch between the MPPT and the battery.
The smaller MPPTs also have a fuse itself directly next to the wire connectors.
kellymeer answered ·
When you mount the controller, it is underneath.
