tfmkevin avatar image
tfmkevin asked
Fallback for Parallel Quattros when one fails?
We have 2 Quattros in parallel on a boat. I understand that if one Quattro fails, the entire system will shut down. Is there a reasonable (manual) way to take the failed Quattro offline and bring the system back up on one inverter?
pracman avatar image
pracman answered ·
Interesting questions. We have to connect and split the system then leave one off I assume. One on without master or slave does not work or change them to single operation. Other issue may be the capacity you used at your site. I could run on one most of the time. I need the capacity of two enough of the time to make one a challenge. If you ran 3 each on a single phase it might meet your objective.
You have to disconnect the communication wires from the defective unit (I would also disconnect the AC and DC wires) and than connect a laptop to the working unit and reset it to stand alone mode.
