la-vie-en-rose avatar image
la-vie-en-rose asked
DipSwitch Settings on Battery Alarm GX
Now I am a little bit confused with the dip switches. The manual gives an example for the standard settings 24 Volt and a low alarm at 21 Volt.
How to configure the low alarm from 21 Volt to 21,6 Volt ? (or anything between 21,5 and 22 Volt?). The reason is that I run a computer network on my boat and I still need a little bit security time for the power supply.)
alarm
With the given examples I would say the reference for 12V is 13.5V and for 24V it is 23V.
So I guess you need to set A2, A3, A5 = ON and the other to OFF to get 21.6V as the alarm voltage.
23V-0,2-0,2-1=21,6
