nfluester avatar image
nfluester asked
2 alternators to 3 battery banks with 1 argofet
Hi there,
i am looking to switch from a competitor to all victron but i cant work out how to integrate the Argofet with my two alternators and 3 battery banks.
is it possible to connect 2 alternators in parallel to the single input of the argofet (obviously if the combined ampage is less than the Argofet rating) and have them split between the three bank?
the only info i found on twin engine installations was to use 2 argofets which i assume means i need to run another separate set of charge leads from the 2nd argofet to the batteries which sounds messy
alternatorArgo FET Diode
