good morning
I Have installed pheonix 12/500 model inverter.then i used to connect with victron connect application there i found charge detect option.what is the use of that option.
good morning
The Charge Detect setting is used to automatically reset the inverter after it has shut down due to low voltage 3 times consecutively. This value can be safely set just below the float charging voltage.
Here is what they say in the Victron manual (linked below):
29 People are following this question.
