fcw avatar image
fcw asked
Newly installed Mppt 75/15 not showing current through the battery monitor
I have two separate solar systems on my boat which run through separate charge controllers. One of the systems has been operational for over a year and is working fine. I notice the charge current going to my batteries through my battery monitor. The new system which I finished installing yesterday shows a current of roughly 4 Amps at the charge controller via the Victron app But I’m not showing that current at my battery monitor. I do have the ability of switching either system on and off so I can clearly see whether I’m getting a charge current at the batteries from either system. Any ideas??
MPPT Controllers
I guess the negative of the MPPT is connected on the wrong side of the shunt (directly at the battery?).
fcw avatar image fcw commented ·
Thank you for the tip. Makes perfect sense
