frednk avatar image
frednk asked
Quattro overload 30 cycle consant power
I have listened to the video https://www.youtube.com/watch?v=4SXtGIx0x5w .
I wish to confirm that when the inverter enters the reduced voltage output mode the current remains constant and the voltage falls as required to keep the inverter running at maximum current.
Paul B avatar image
Paul B answered ·
As per the video, the amps will try to be held at the max level and it will try to bring the voltage up to the required level within 30 cycles . this amps level is the units rated output level at the standard rated temperature.
frednk avatar image
frednk answered ·
Thank you. Words used were "constant power", I wanted to make sure that wasn't what was being attempted.
