camillanorberg avatar image
camillanorberg asked
Multiplus 3000 stop charging
We have a Multiplus 24| 3000 | 70 and we use it early this morning and then we turn it off. When we start it again after a couple of hours it will not charge the battery.
We have 2 different input source, a generator and solar cells and same problem so it must be a problem with the multiplus.
Anyone who has any idea how to find the problem?
battery charging
Luis del Campo avatar image
Luis del Campo answered ·
Hi. I understand that your Multiplus receives power from a generator and the solar cells charge the batteries through a controller. Is the controller working fine? Batteries chargue properly with the sun?
If the problem is only with the Multiplus, generator is new? Has this worked well before? I once had a problem with a Multiplus 24/3000/700 and it was caused by generador instability. Again I had another problem and the cause was very old batteries.
