wolfgangr avatar image
wolfgangr asked
MultiPlus II switch on/off in cycle of 7...8 seconds with load below 100 watt
I use the MultiPlus II in a stand alone setup in a cottage. The problem is that the inverter is switching on/off with low consumption. It changes above a threshold of > 100 Watt.
That cannot be normal. Still waiting for an answer from my dealer (GreenAkku) but the don’t answer my ticket.
Hoping for your support. Thanks in advance!
Multiplus-II
Any red LEDs? Other components? What happens if you disconnect all loads?
@WolfgangR
The AES function may be enable and the settings is in just the wrong range to keep the inverter either on or off. It can be set in the inverter tab in VE Config
Paul B avatar image
Paul B answered ·
I would agree with alexandra,
