actpiet avatar image
actpiet asked
BMV 600s displays 83Volts on a 12V battery
I have
factory reset to no avail. I have set all the individual parameter manually to no avail. Disconnected the BMV - no change. Connected to a new shunt no change. Connected to new battery - no change.
It just continues to display system voltage in the high 70s to low 80s. I have replaced with a newer model 712, but would like to know what the likely cause of this malfunction is to ensure that I don't suffer this failure again.
thanks
BMV Battery Monitor
demiguelrodrigo avatar image
demiguelrodrigo answered ·
I have. Similar problem in a 600S. It reads 77 volts on a 12 volt battery bank.
Did you manage to solve the problem?
Thanks.
