greendovefarms avatar image
greendovefarms asked
Firmware update 2610159 or 2610475
Hi is there any reason not to update firmware on a multiplus 24-3000-70 with current firmware 2610159 to 2610475 ?
What kind of setup do you have?
The most changes in the 4XX FW are related to ESS.
If you want/need to use the assistants you need to update.
If your system is running without issues there is no need to update.
Save yous setting before the update! The update will reset all settings to default!
