I am adding a BMV-712 to a CCGX and i am wondering if I need a VE.Direct cable between those to get the State of charge in the CCGX or can they communicate via Bluetooth?
If i need a VE.Direct cable, what kind is that?
Hi @johangunnar The ve.direct cables come in straight or with one end right angled versions at various lengths. No bluetooth connection with the CCGX possible. Just make sure you have a free ve.direct port on the CCGX otherwise you will require a ve.direct to usb cable.
20 People are following this question.
