kc-au avatar image
kc-au asked
Single Phase - Dual MultiPlus - dual battery banks
I have received 2 battery banks. 48V (both), one is 200AH, the other is 280AH. Different brands.
My initial intention was to have 2x MutliPlus, one on each bank, and the MP on a single phase.
Reading the install guide, i read that 2xMP on single phase must be on the same battery bank.
I didnt want the batteries in parrallel as they are different capacities and different brands and will lead to a heap of issues.
Am i reading the dual MP's must be on a single battery bank correctly? I was hoping the MP's could parralell together to double the output, but each manage their own respective battery bank.
Multiplus-II
solardude avatar image
solardude answered ·
Can it be done? Sort of. Is it advisable? No.
When configured in parallel or split phase, both inverters need to share a battery bank. You WILL have problems on different banks.
4 comments
ejrossouw avatar image ejrossouw commented ·
... also, not installing it in line with the manufacturer's instructions will invalidate warranties as well support will not be available.
No!! it cannot be done on parallel or multiphase systems!!!!
the 'master' Multi controls the charging / discharging, and connecting both to different batteries will cause havoc, might destroy inverters / batteries, etc.
Please read:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
marekp avatar image marekp Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
What will happen, if one would connect each mutiplus with is own battery to separate AC circuits at home?
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ marekp commented ·
Hi @MarekP
That is of course no problem, being two independent systems.
but don't try to parallel them, they need to be independent.
kc-au avatar image
kc-au answered ·
you say sort of... can you expand on that? Are you talking battery combiners and isolators?
Sorry @kc_au
it cannot be done, you'll have to configure two different systems with two separate battery banks.
