jer-dem avatar image
jer-dem asked
MPPT 75/10 :current readings are false
Current readings on victronconnect with my MPPT 75/10 are quite surprising: with a fridge connected on load port, when the fridge is running, the value readed is 0.6 A instead of 4.5-5 A on a multimeter. Solar power increase to something like 45W, battery current 2.6A at the same time.
I believe my setup is right as it works well, but I can't rely on the readings (and I'm furious as I bough the bluetooth dongle to have a good monitoring of my intallation).
Does someone else have the same issue (mppt firmware: v1.5, victronconnect V5.27) ?
MPPT Controllers
