Peter Buijs - NL avatar image
Peter Buijs - NL asked
Quattro Solar configuration
What is there already
- Quattro 24V 8000VA 200Amp 1943143
- Color Control GX FW 2.54
- BMV-700 FW 3.08 including Shunt
- 6x AGM battery 250Ah, Series/Parallel bank 24V-
- Outback Flexmax 60 Solar Charger-
- 13x Solarpanel 155W I 5,08A
- Generator set 230V 30A
What we want to accomplish
- Use as much Solarpower as possible
- Switch Generator when needed within timeframe (not at night)
- Only use AC shorepower when stricly needed (costs)
What we think is needed
- Run the latest firmware on the Quattro (FW159)
- A Battery Balancer to protect the series/parallel 24V battery bank.
Questions
- Will this be possible with Virtual Switch FW159 on the Quattro
- Or is it advisable to take a look at Assistants to accomplish this.
- What can we do with the alarm output of the Battery Balancer in this configuration
- What should we do with the setup of the 2 chargers (Outback / Quattro)
Suggestions
- Any suggestions to look in to
Peter Buijs - NL answered ·
Since there was no reponse this is how we proceeded.
- Updated the firmare to 159
- Configured VSwitch with AC Ignore
- Configured CCGX to start Generator on SOC
- The Outback charger will be replaced a.s.a.p. with a MPPT 150/70 ve
Phil Gavin avatar image Phil Gavin commented ·
If you haven't done this already.
In the VRM System setup, you should enable "Has DC system", to see the outback's contribution.
