knauer avatar image
knauer asked
VE.Direct: DTR AND RTS high or OR?
Hey,
the FAQ
https://www.victronenergy.com/live/vedirect_protocol:faq#q2when_using_the_vedirect_to_rs232_interface_what_pins_do_i_need
says first "the DTR signal [...] and/or the RTS signal [...] must be driven high ". Three sentences later, it says "When one of those pins is not driven high, you will not be able to receive data!"
So, what is true: Must BOTH be high or is ONE of them enough?
VE.Direct
knauer avatar image knauer commented ยท
Could someone of the staff please answer? This MUST be of Victrons knowledge and I consider this an error in the documentation, so as a customer I'd expect an answer.
0 Likes 0 ยท
