What are the settings for a 32v system and what is my battery capacity if I have 4ea 306ah 8v batteries in series? 306ah or 306x4?
In series, the voltage changes and ah remains the same. You would have a 32V 306ah pack. I am not sure of the settings, as 32V is an unusual setup, and settings vary based on battery construction.
According to the BMV712 manual, Pg 15:
In case of another nominal battery bank voltage (32V for example), the charged voltage must be set manually: see section 4.2.1, setting 02.
That section starts on Pg 21
The manual is here:
https://www.victronenergy.com/upload/documents/Manual-BMV-700-700H-702-712-EN-NL-FR-DE-ES-SE.pdf
17 People are following this question.
