Can I update Multiplus Firmware 2624159 to 26244xx?
Hi @Jaqibar
Yes you can. You'll need a MK3-usb adaptor (& a lappy?), and you'll have to use VEFlash.
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
There's all sorts of warnings, but the procedure is actually quite simple and troublefree if you follow the instructions.
Hola from Spain. I have a customer with an old Multiplus 48/5000/70-100 230V with new microprocessor (26) and stock firmware 26 24 155 what sais on the sticker on the microprocessor. I can not find the right device in the list of firmware online in victron profesional and also not in the VEbus firmware text file for this inverter.
I need to update the firmware to the multiplus to get rid of the error message 48 given by the cerbogx device installed now together with lithium pylontech batteries and a new mppt smart solar charger from victron. The system is working fine, but the error 48 is there and it's not posible to conect via vrm. Please help, what firmware file to use and update to the multiplus. Thank you, Gracias, Danke! Regards, Marcus.
Marcus.
The latest firmware on Victron Professional is 2624502. It's actually a '400 Series' fw, so look for it there. (A lot of added features since 155).
VE.Flash (Win PC) is available from the Downloads section of the Victron website (VEConfigururation Tools).
VE Flash is only necessary because the existing fw is so old. There are more modern ways for updating later VE.Bus fw.
20 People are following this question.
