giancarlo64 avatar image
giancarlo64 asked
Easy Solar 24/1600 Absorption and Float LED blinking
I have a problem with a EasySolar 24/1600/40-16 MPPT 100/50.
I have installed as follow:
PV Modules: 2 x JA Solar Mono JAM60S01-315/PR
Umpp = 33.16V Uo= 40.53V Icc= 9.98A
The Modules are connected in series so:
U_PV_IN = 81.06V I_PV_IN= 9.98A
Batteries: 2x AGM 12V/220Ah (100h) in series
The temperature sensor is connected on the minus pole of the batteries.
If the Inverter switch is on the inverter work fine but if I switch it to charger position the absorption and the Float leds start blinking.
What's wrong?
Regards
Gian Carlo
battery charging
