My newly installed 24/5000 multiplus isn`t switching to battery when solar PV cuts off
I have a Abb Aurora 5kw ca coupled inverter coupled to the multiplus
Any reasons??
Any reasons??
OK, so you need an Assistant loaded into the MultiPlus. An assistant is like an "App" for the MultiPlus. It enables it to do more special tasks like what you want to do.
The MultiPlus needs to know that there is a PV Inverter there otherwise how can it know that it should use energy to charge.
You need to use VE.Configure to do this then you can set up the Assistant. You configure the Assistant by telling it how powerful your Aurora is, how much PV power you have installed.
I did not ask you if you have a Venus device like CCGX or Venus GX? If not, then you can just use the "PV Inverter Support" Assistant.
5 People are following this question.
