cerpentier avatar image
cerpentier asked
Victron MultiPlus C 12/2000/80-30 AC input is 230 V display shows 105 / 168 volt, inverter does not start up.
When AC is disconnected the display reads a input of 15 V....? When AC connected display reads between 105 / 168 Volt
All disconnect and startup scenarios have been executed.
Where is the location of the 30 Amp Fuse between Shore and Victron (thermal circuit breaker)
Hi, please contact your dealer to have the unit tested and/or check your wiring.
See here:
https://www.victronenergy.com/support
I hope its sorted soon; if not already.
